Graphic Cards LED monitor buying advice. confused
anil_sethi
Inactive
Contributor
my gfx is saphire amd firepro v4800.
I want led monitor not too big not too small ( witin 20 to 22 inch range ) . for editing video purpose.
confuse between.
1. BENQ 22" G2222HDL Full HD
or
2. LG E2060T 20†W Slim & Sleek
LED Monitor
or suggest any other good monitor price range below 10k.
and should we watchable with all the angles and last for atleast 2-3 years.
thanks.
If you want to Panel which you can watch with any angle then you'd have to get an IPS PANEL wich is above 14k so these are the best within your budget-
DELL ST2220L-8.2k or Dell S2330MX[23" Ultra slim]-10.5k i'd say go for dell 22 or 23".
