Monitors Looking for 18.5" LED MONITOR - Mumbai
saurabhazad
Inactive
Beginner
Hi,
My Brother - In - Law is looking for 18.5" LED Monitor in MUMBAI.
He is getting AOL 18.5" at Rs. 5,700/-.
Can anyone suggest any better monitor at a competitive price or a better price?
Thanks
yeah ..by extendig budget by 1K ..you get a much bigger monitor ! ..i';d say go for it !
my bro has 22" AOC its great at build , price, performance, service
As far as I know AOC Monitors come with only one year warranty, so I would suggest you to buy one which has atleast 3 years warranty and is priced nearby 6000. I would recommend you to go with Acer P196HQL which comes with 3 years warranty. Acer P196HQL comes with the following configuration: 47 cm (18.5") Wide Display, 16:9 High Definition, 410x230mm, Resolution:1366x768@60Hz, Pixel Pitch:0.300 mm,Contrast Ratio:8000'000:1 (ACM),Brightness:250 cd/m2, Response Rate:5 ms. With LED Tecnology. You can buy this monitor from Bitfang.com at only Rs. 6,370/-
