High performance development workstation
Folks, I want to set up a high performance development workstation which should be able to play/deliver full HD video flawlessly.
Q: What is your budget?
26K can stretch by 2K
N.A. as no desktop yet. Some components to be used mentioned below.
Monitor - Dell E1609W with Max Resolution of 1366 x 768 / 60 Hz and VGA connector
HDD - Seagate Momentus Laptop HDD 320 GB
Keyboard - Enter USB
Mouse - Logitech M90 USB
Speaker - X-mini MAX
Optical DD - Liteon iHBS112 Blu-ray Burner
HDD - Seagate Barracuda® Green SATA 3Gb/s 2TB Hard Drive ST32000542AS
Q: Which hardware component are you looking to buy (component name).
Primary requirements are low power consumption and high computing power
CPU - Intel Core i5 2500K
Motherboard - Intel Z68 chipset based with USB 3.0, HDMI and 1600 DDR3 support
GPU - Should support Full HD/Bluray playback and casual gaming, on board Intel HD 3000 should suffice for now
RAM - 2 x 4 GB 1600 DDR3
Cabinet - Any uATX good brand with flexibility and sufficient air flow
PSU - FSP SAGA II 500
CPU Cooling - Not sure, open to suggestions. Is the i2500k stock cooler good enough for moderate overclocking ?
Q: Is this going to be your final configuration or you would be adding/upgrading a component in near future.
Yes, will upgrade the following within 6 - 8 months
Add 2 X 4 GB more RAM (total 16 GB)
Additional SSD 60 GB
Full HD LED display
May add a discrete Graphics card as well
Kolkata, open to online purchase
Yes
Primary requirements are stability, high computing power and performance, expandability
Mainly to serve as a development workstation with win7/linux. I will deploy Oracle database and certain application servers.
Virtualization using virtualbox, vmware, etc.
Watching Bluray/HD and video transcoding
Casual gaming for now
Would prefer Intel CPU. For others, established brands with good after sales service in Kolkata would be preferred.
Casual gaming
Full HD LED display for HD/Bluray playback
Yes, I may do some moderate overclocking but without losing stability
Windows 7 Pro 64 bit
Linux - openSUSE, Ubuntu and Mint 64 bit
Full HD LED display
Yes
Casual gaming
