Gaurish said:Its confirmed India ISP are among the BitTorrent Throttling ISPs
All the major Indian ISPs - BSNL, VSNL, Reliance, Airtel are in that list.
rahulyo said:Hi TE ppl ...
I have BSNL Home 500 plane...
Whenever i try to download Torrents i got very low speed (50-70KBps) ...
But on rapidshare i got 150-200kbps speed ...
Why this happen ????
isn't home 500 a 256kbps plan ??
download speed is only a max. of 33KBps rite?
then wats this bout 150-200 & 50-70 KBps?
Do enlighten me..
Hacker said:Can you post some links???
My friend gets 180 to 200 kbps download speed during bsnl happy hours, so i dont think wat your saying is true.
Gaurish said:I have already given
http://www.techenclave.com/800573-post6.html
as Rahulrulez said the download speeds range up to 2 Mbps max with 256 kbps being minimum. Recently the upload speeds have gone up to 512 kbps.thetoxicmind said:isn't home 500 a 256kbps plan ??
Do enlighten me..
Kumar said:me get allmost 100% speed on my VSNL 256 UL too.
agreed. a previous poster said seed to leech ratio makes all the difference. example. seeders: 27 leechers 114= good. seeders 51 leechers 178= bad.. slowNamic said:my feel is that you shud check the utorrent settings......
