Laptops Macbook Users: Please post your power consumption numbers (System Profile> Power)here
superczar
Juggernaut
Would really appreciate if some of the Macbook owners can post their Amperage readings while running on battery
(what good are these readings, well, for starters, the system battery capacity (in mAH) divided by the power draw (mA) will give you a real time value of the battery backup time
Mine reads:
Display (dimmest) with wifi on: -744 mA
Display (medium) with wifi on: - 789mA
Display Max with wifi On : - 919mA
Full set of readings:
Model Information:
Serial Number: SMP-bq20z951-3932-794
Manufacturer: SMP
Device name: bq20z951
Pack Lot Code: 0000
PCB Lot Code: 0000
Firmware Version: 002a
Hardware Revision: 000a
Cell Revision: 0100
Charge Information:
Charge remaining (mAh): 2851
Fully charged: No
Charging: No
Full charge capacity (mAh): 4077
Health Information:
Cycle count: 7
Condition: Good
Battery Installed: Yes
Amperage (mA): -769
Voltage (mV): 11673
Here is how to get these readings:
Open System Profiler>Power
You need to refresh the readings (Command-R) a few seconds after changing the brightness (or any other setting that would change the power draw)
Also, can you please post your system sleep power drain (You can get the value by keeping system profile>Power window open , close the lid (put system to sleep)
The wake system after few seconds and quickly refresh the power readings (Cmd+R) - The value you will get for the first few seconds is your system's sleep drain
Reason why I am acting so fussy about these readings is here:
http://www.techenclave.com/962920-post9.html
Now I am trying to assess if the notebook is able to manage the power draw efficiently while running on batteries
even though the notebook is eligible for a DOA, the process is going to be a bit convoluted because it is an international DOA and seems like it may take upto 2-4 weeks :(
Display (dimmest) with wifi on: -816 mA
Display (medium) with wifi on: - 1017mA
Display Max with wifi On : - 983mA
Model Information:
Serial Number: SMP-bq20z951-3937-11dd
Manufacturer: SMP
Pack Lot Code: 0000
PCB Lot Code: 0000
Cell Revision: 0100
Charge Information:
Charge remaining (mAh): 3911
Fully charged: No
Charging: No
Full charge capacity (mAh): 4192
Health Information:
Cycle count: 17
Condition: Good
Amperage (mA): -1036
Voltage (mV): 12205
Hope it helps mate! Lemme know if you need anything else :)
These readings were at 93-95% battery capacity icon btw.
Thanks mate
Just one more thing
Can you post back your standby/sleep numbers
(Put machine to sleep with system profile>Power in the foreground... Wake machine after 15 seconds and do a quick refresh (cmd+R) to note the Amperage reading)
387mA
That's funny...maybe you resumed the system before it went completely into sleep mode
How much charge do you lose overnight? (Am assuming you just close the lid instead of shutting it down)
Display dimmest + wifi = Amperage (mA): -1216
Display medium + wifi = Amperage (mA): -1033
Display max + wifi = Amperage (mA): -945
Model Information:
Serial Number: SMP-ASMB016-38af-c76
Manufacturer: SMP
Device name: ASMB016
Pack Lot Code: 0000
PCB Lot Code: 0000
Firmware Version: 0110
Hardware Revision: 0200
Cell Revision: 0400
Charge Information:
Charge remaining (mAh): 5030
Fully charged: Yes
Charging: No
Full charge capacity (mAh): 5100
Health Information:
Cycle count: 8
Condition: Good
Amperage (mA): -1162
Voltage (mV): 12358
Sleep Drain : Amperage (mA): -304
superczar said:
387mA
Not at all! I put the system to sleep, waited a good 12 secs for the sleep light to start pulsing (Indicating that its in sleep), waited for another 15 secs and then resumed and refreshed.
I loose about 4-6% charge overnight in sleep (8-9 hours).
