FS: Power Cooling and Modding MADE IN INDIA Power Supply Extension Cables
napstersquest
Thread Police
Feedback: 81 / 0 / 0
Aurangabad, Maharashtra
Packed Brand New
  1. Bank Transfer
Included in cost
3 Months
No
I am the manufacturer (?!)
Except for the connectors, everything including cables and sleeving material was procured from Indian manufacturers during lockdown. Have 4 sets left (might update with a few more)
Expected price is Rs 2000/set.
Each set contains: 1x24 pin ATX extension
2x (6+2)pin pcie extension
1x (4+4)pin eps extension
All cables are 30cms in length approx, and each cable has 4 transparent acrylic cable combs.
Shipping from Aurangabad, Maharashtra. Shipping fee is included.
Hey man, Great stuff you are selling at a fair cost. If you plan to make more of these then make sure you have some sort of bend in the cable. ie the inner ones are shorter ones. It helps a lot while in use.
how did you achieve this? can you give me some explanation that would be nice.
Basically this
Thanks!
Yeah one issue with that is sometimes some cards need curves in one direction and others in the other direction. Hence chose a neutral colour theme as well as safe bet on size etc.
