Q: What is your budget?
28k
CPU - Phenom II x4 955
Motherboard - Biostar TA 790GXBE
GPU - ATI 4350
RAM - Corsair XMS2 4x2gb DDR2 800mhz
Monitor - No monitor
SMPS - Corsair VX450
Cabinet - Zebronics Bijli
DVD writer - Samsung Octoedge Sata
GPU - ATI 4890 1GB / ATI 5770 1 GB (max 12k )
Cabinet - CM 590 (4k-4.5k)
Monitor - Samsung 23" P2350 (max 12k) { No to Benq. Not becoz its bad or something but becoz it's Benq G2412 , Benq G2420 is not available here and my DAD won't settle for online buying. If i insist i'll have to drop the idea of buying anything }
Yes, will upgrade the following within 6 months
CPU - Core i5 750
SMPS - Corsair TX 750
RAM - 2x2GB DDR3 1333mhz Corsair/Transcend
Mobo - Intel DP55WB/ Intel DP55WG
Kolkata
No
Gaming
Browsing
Desktop Processing
HTPC
Download rig, (for 2am to 8am everday)
Watching HD movies
Dell , Samsung for Monitors
Batman Arkham Assylum
Racing - Grid high settings , NFS Shift high settings, Dirt 2
Gaming - 1920x1080
Desktop - 1920x1080
No
Windows 7 64 bit
Note : { No to Benq . Not becoz its bad or something but becoz it's Benq G2412 , Benq G2420 is not available here and my DAD won't settle for online buying. If i insist i'll have to drop the idea of buying anything }
28k
GPU - ATI 4350
CPU - Core i5 750
Kolkata
No
Gaming
Browsing
Desktop Processing
HTPC
Watching HD movies
Gaming - 1920x1080
Desktop - 1920x1080
No
Windows 7 64 bit
