Budget 51-70k my budget is 70k need parts suggestions
Broly4878
Recruit
i need help picking mobo , cpu and gpu ...already have 650 watt psu ,ssd ...my bro is saying buy 9700x with b650 ...get gpu later and my idea is b 60 +ryzen 5 7600 and 4060 ....do u have any balanced suggestion ? will be grateful thanks
Ryzen 9000 is a blind no for now, overpriced.
No point spending money on anything more than R5 7600 for gaming, unless your budget allows you to get a GPU like RTX 4080.
I highly recommend increasing the budget by 10k to buy 7700XT to match PS5 Pro's GPU performance & not be limited by 8GB VRAM. Else reduce CPU to like i5 12400 + DDR4 rig to accomodate 7700XT within 70k. An i5 12400 + 7700XT will almost always outperform an R5 7600 + 4060, that too by a huge margin. The i5 12400 won't bottleneck 7700XT, if you are worried about that. Heck I use i5 12400 + DDR4 system & recently upgraded GPU to 7900GRE & see no bottleneck (I know there's some bottleneck here, so won't recommend this for new rig builders).
Check if the 16k deal for R5 7600 on amazon is still live.
