FS: Others Nakamichi : Android Power Amplifier
nsas02
Galvanizer
Feedback: +28 / =0 / -0
Chennai
4 out of 5
  1. Cash
  2. Bank Transfer
Excluded - at actuals
No
No longer needed
Selling my 1.5 years old Nakamichi Android Power Amplifier. Model # NGQ-A4251
Doesn't need external power; Connects directly to the Android Head unit via provided cable. Can be installed by self.
My Android head unit was very slim (I guess most of them are) and this sits perfectly behind the head unit, hidden.
Open to shipping, but at buyers risk and cost. Local buys will be preferred.
(Purchase date is just a placeholder)
Can this be installed in Honda city. Will you be able to fix it.. btw am from Chennai.
Do u have Android Headunit? I mean, aftermarket one? In fact I removed this from my Honda City only, but mine was an aftermarket Headunit. So not sure about OEM Headunits.
Well mine is OEM one. How good the audio will be as mine have only OEM speakers.
To start with, I'm not sure if this can be added to the OEM Headunit. I've used it with an aftermarket unit, and the audio quality improvement was immediately noticable.
Guys, fitting a new stereo or an amp to a new stereo is something that any car accessories person will do for 2-3k max. In Bangalore , I got installed double layer damping + reverse camera + front and rear components + a head unit, all for 7.5k (This included a frame worth 1000). So the labour alone was just 6k for all this from one of the famous accessories shops. Most likely you can add the amp to the OEM head unit, but it is likely that the OEM speakers are so bad that they wont sound very different by using an amp alone. Better to get the Nakamichi amp and also add atleast front components.
While this can be fitted in any car, it will need a head unit with a matching connector (apparently common to most generic Android head units) to work.
It will not work with a lot of oe and branded head units
Reactions: Kilroyquasar
For that pioneer this is probably will not make any impact. You have proper RCA outs. Get a proper amplifier
This is more for chinese head units which have very puny built in amplifiers and something like this brings their quality up to slightly better than a branded one
Reactions: blackscorpio
