Graphic Cards Need a 6 pin Power cable for my Card
Lord Dagon
Contributor
guys i brought 6800gt from my friend , since he not using this, the problem is i don't have the 6 pin power cable so does anyone have extra or where can i find in bangalore.
thanks in advance.
No where... You have to be very lucky to find one... Maybe now it will be easy to find but i have my doubts... For the very same thing last year i had to buy two new PSU's :@...
P.S. There is a certain TE member who can make you one of those but its gonna be a little bit expensive ;)...
Searched all the shop in SP road , No luck.
Bought a 4 pin mole x extension cable , saw a the pin config on the net and i removed the the mole x at one end and using it. HOPE notting will happen to the card.
And is any 1 have it please send it to me , it would be a great help .
else other option would be to nicely ask fellow te members who have got this cable with their card but they r not using it as their psus come with the cable direct
i gave mine to a friend too :P
