CapriAnupam
Hi guys,
I am looking for a good quality, durable, and long lasting wireless mouse.
I am willing to spend up to INR 1200 for a good mouse. Maybe a bit more if the quality is really good, and it will last longer.
I haven't owned a wireless mouse till now, but I think it is time to own one.
I have been buying wired Logitech mouse since I have been using personal computers. They were very good in early years, but lately, I feel that their quality has gone down significantly. Their mouse, or even keyboards, start to misbehave pretty early. I have a Logitech M105 currently, which I had bought for use with laptop... sometimes has the problem of right click menu coming up when I click the left button.
I even tried an HP mouse before that, but that too went bad just after its warranty, with its scroll button not working. Add to that, no one repairs these mice. Would be great and cost effective and also green, if a simple thing such as a bad scroll button was fixed. But no, they just want you to throw a rather good mouse away, and make you buy a new one.
Anyways, I want a wireless mouse for simple desktop usage. I am not a gamer. I just need it for day to day usage, like browsing, watching movies, etc. Not heavy stuff as such, but yes, I do tend to use the PC throughout the day sometimes, and that way, usage can be more. But, I am planning to cut on that.
I only have idea about Logitech mouse. So, from the Logitech site, I shortlisted some choices.
M331 Silent seems to be best.
M235 does not support Linux, so I did not consider it. I do not use Linux currently, but do intend to try it out in near future.
M190 seems large and also doesn't have silent clicks, so left it out.
M221 is a choice, but M331 seems better for the long run.
If there are any other good suggestions from other brands, please suggest. Remember, I have no idea about the quality of wireless mouse of other brands, so please suggest really good quality mouse. I always look for products which will last a long time without any issues, because I operate in a budget, and cannot afford to spend money frequently.
