- Q: What is your budget?
- 20K
- 20K
- Q: What is your existing hardware configuration (component name - component brand and model) : NA
- Q: Which hardware will you be keeping (component name - component brand and model)
- Monitor - Samsung P2450
- Q: Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement.
- CPU
- Motherboard with integrated Gfx
- RAM
- Cabinet
- HDD
- PSU
- CPU
- Q: Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component : N/A
- Q: Where will you buy this hardware? (Online/City/TE Dealer)
- Online in the US
- Online in the US
- Q: Would you consider buying a second hand hardware from the TE market
- No
- No
- Q: What is your intended use for this PC/hardware
- Browsing
- Desktop Processing
- HTPC
- 24x7 operation
- Watching HD movies
- Browsing
- Q: Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike : N/A
- Q: If you will be playing games then which type of games will you be playing?
- NA
- NA
- Q: What is your preferred monitor resolution for gaming and normal usage
- Normal Usage : 1920 x 1080
- Q: Are you looking to overclock?
- No
- No
- Q: Which operating system do you intend to use with this configuration?
Windows 7 64 bit
I am currently in the US and will buy the components online. Looking forward to your suggestions.
Thanks
