· Q: What is your budget?
As low as possible without compromising on quality.
· Q: What is your existing hardware configuration (component name - component brand and model)
None.
· Q: Which hardware will you be keeping (component name - component brand and model)
None
· Q: Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement.
> Depending on price I’d prefer cheapest dual-core, (The E5300s etc) OR entry level Core i3 (Only if performance difference between dual-core and corei3 is impressive enough to shell out more mullah!) OR entry level/midrange AMD dual-core. I’m leaning towards AMD due to the fact AMD offers more bang for the buck (Mobo has more specs for less/same cost)
Motherboard – Gigabyte is top priority! USB 3 ready mobo. Don’t know model name.
Prefreably corsair value select 4gb 2x2 ram.
500 GB WD Hdd/Samsung DVD Writer.
GPU/Sound = Onboard.
I-Ball pride cabinet.
FSP SAGA 350W PSU OR Corsair entry level PSU (Builder series??)
External TV Tuner card which will work with TataSky.
· Q: Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
>No plans as of now.
· Q: Where will you buy this hardware? (Online/City/TE Dealer)
> Mumbai. Not open to online purchase.
· Q: Would you consider buying a second hand hardware from the TE market
> No
· Q: What is your intended use for this PC/hardware
· Q: Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
Gigabyte mobo/corsair ram/corsair or FSP Psu. No Asus.
· Q: If you will be playing games then which type of games will you be playing?
None!
· Q: What is your preferred monitor resolution for gaming and normal usage
A 22†preferably a 16:10 Dell OR BenQ LCD.
· Q: Are you looking to overclock?
No
· Q: Which operating system do you intend to use with this configuration?
Windows 7 86 OR 64 bit.
None.
None
>No plans as of now.
> No
- Browsing
- Desktop Processing
- HTPC
- Download rig, 24x7 operation
- Watching HD movies
None!
No
