Budget 0-20k Need advice on USB Hub
belictony
Member
I have a laptop and PC. I use wired keyboard and mouse. I connect the laptop to the PC monitor via HDMI and the PC to Monitor via Display Port.
Need a good USB hub which has HDMI and 3 USB 3.0 ports and Gigabit Ethernet to switch keyboard and mouse easily to desktop.
Laptop has USB C PD port but desktop doesn’t. So connectivity is through USB 3.0 port.
please suggest good models
vivek.krishnan
Veteran
You need a KVM switch I think. Else use RDP or Teamviewer on either to connect to the other.
