krishna_chennai
Hi All,
I am planning to replace by good old Belkin Router with a faster one given my infra (read gadgets) at home has seen a change. Managed to zero on the following requirements:
I have not shortlisted any models....Thanks for your advice!
PS:Thanks @_Atif_ for the template
- Budget - upto 7k
- ADSL & Fiber Router. The one that takes LAN cables also as input in addition to phone cables.
- Router will be used to browse the internet and stream HD content from my NAS
- Should be dual band router.
- Should have good enough range for a 1500 sq ft flat.
- Should be able to handle 8+ devices - 4 phones, 1 desktop and 1 printer. I also have a Dune Prime & TV which would share the connection.
- USB ports are good to have but not compulsory.
- I am not interested in modifying the router(custom firmware, etc).
- While I would like to pick a AC router, I am not sure if my budget would allow the choice. I am looking for a N600 router to the least. Considering what I use is a very basic Belkin which I bought 4 years back.
