Hi Fellow members,
I am looking for your help in upgrading my PC to run games released in last 2 years time frame ( Just to kill time during corona times) . As long as game runs smoothly, I am not bothered about graphics quality. My current pc is not able to run latest DLCs of Frostpunk smoothly.
- What is your budget?
- Max 10k
- CPU - Intel i5-2500K @ 3.30 GHz
- Motherboard - Asus P8Z68-V
- GPU - ATI /AMD 6450 HD
- RAM - Corsair 8 GB * 1 DDR 3
- Monitor - Dell 2409
- PSU - Corsair VX450
- (please mention the rest in above format)
- GPU
- RAM ( if required )
- Highly unlikely. Only if I am convinced that my current system is a piece of Junk I may go for a quality new rig altogether.
- Chandigarh
- Open to online purchase
- No
- Gaming
- Browsing
- Desktop Processing
- Download rig, 24x7 operation
- Watching HD movies
- No
- FrostPunk
- Assassins Creed
- Tropico 6
- Gaming - 1280x720
- Desktop - 1280x720
- No
- Windows 7 64 bit
