sachu0203
Recruit
- What is your budget?
- 30K
- NA
- Monitor - Samsung 21 inch
- CPU
- Motherboard
- GPU
- PSU
- RAM
- HDD
- Cabinet
- (please mention the rest in above format)
- Not immediately, but may upgrade sometime in future
- Pune
- Open to online purchase
- No
- Gaming
- Browsing
- Watching HD movies
- Normal home usage
- NA
- Action - Assassin's creed
- Racing - Grid at medium to high settings, NFS, Formula 1 2011
- No preference.
- No
- Windows 8
