Graphic Cards Need Help for Sapphire RX 460
itechankit
Inactive
Contributor
Hello,
I have ordered Sapphire RX 460 and Corsair vs450 power supply.I want to know that does this card draws power from motherboard or i have to connect it to power supply?And if yes which socket of power supply it needs?
The vs450 already has a 6-pin connector.. So no need to buy any separate converter..
when you get the psu, just check it.. it will be written "PCI-e" on the connector itself..
In the link you have posted, the black colored end is the 6-pin connector...
@swagatrath where to plug this connecter?Port of 6pin will be on graphic card?Actaully i have already bought mother board.Its ECS motherboard c2 series h110m chipset
@swagatrath
thanks a lot bro,i was very very worried by thinking that this 6pin slot will be on motherboard.Actually i have opened box of motherboard.But thanks as you confirmed this port is on gfx.
i will update when i get the graphic card.
