PC Peripherals Need help in buying air or watercooling for my pc
manojbn
Beginner
Iam going to upgrade my pc .like some monster gaming and ive decided mother board and processor and I really need help in buying a cooling machine for my processor .
My rigs are:
AMD PHENOM II x6 1090t processor.
EVGA Classified 4waysli mother board.
XFX HD Radeon 5870
And i have a nzxt phantom chassis.
please help me with cooling option.
Firstly,
Triple post .... :@
http://www.techenclave.com/cpu-mobo-corner/need-help-buying-air-watercooling-my-182243.html
http://www.techenclave.com/pc-buying-advice/need-help-buying-air-watercooling-my-182242.html
Secondly,
It would be good if you specified your budget. While a good air cooler can range from 3k - 6k without fan (except DH14). A watercooling kit won't be easily available here, will not be easy to install/fit, risky (if you are not careful enough while checking for a leak) and most importantly can cost anywhere from 8k upwards without fans.
