Budget 71-90K Need help in deciding PC Parts
coolmridul
Recruit
Budget - 80k - 90k
Making my own PC for the first time
CPU - i5-10400F
GPU - 1660 Ti 6GB
MB - B460M HD gaming
RAM- Corsair 8x2 GB 2666Hz RGB
PSU - Antec high current gamer gold 650 W
COOLER - Cool master hyper 212 RBG
HD - Kingston A2000 256 SSD + WD Blue 5400RPM HDD
MONITOR - Msi optix g241
CASE - Cool master MB311L ARGB
MOUSE AND KEYBOARD - 5K
Also, Where should I buy these parts from?
Budget - 80k - 90k
CPU - i5-10400F
GPU - 1660 Ti 6GB
If possible visit the local market. And if not than primeabgb, mdcomputers, and many more are your best options.
nice parts buy maybe drop the HDD from the build and up the SSD to 1TB, rest all looks good
I also have a new NZXT H210i case on sale for cheap if you wanna build into a High Quality ITX case
Get better ram atleast 3000mhz as the new generation cpu helps with higher frequency.
And it is better for gaming and workloads.
Try to get from local market otherwise wait for Christmas sale you might get ram and ssd in cheap online.
Budget - 80k - 90k
CPU - i5-10400F
GPU - 1660 Ti 6GB
Get a ryzen 3600 based system.
Ram 2666 MHz is fine as with XMP board, it can go upto 3200 Mhz
PSU is overkill unless you want to upgrade CPU / GPU in future
SSD is fine but if you are gaming, get atleast a 500 GB SSD for 2nd drive
Please fill this one, you will get better help in deciding your first rig.
Just saying if you don't mind used you can go for GTX1080(if you lucky 1080ti) or RTX2060 for cheaper in price and batter in performance instead of gtx 1660ti
compare the prices from local market and online.
Go for RTX 2060
Primeabgb vedantcomputers
Check before buying with mdcomputers,
They cancel the order due to shipment, refund money after 10days...
They receive money first then check pincode is serviceable or not...
Budget - 80k - 90k
CPU - i5-10400F
GPU - 1660 Ti 6GB
Budget -98.9K
AMD Ryzen 5 3600 -18.9k
MSi B450 Gaming Pro Carbon MAX Wifi -12.9k
ADATA XPG SPECTRIX D60G RGB 16GB (8GBx2) 3600Mhz -9.2k
Kingston A2000 1TB NVME SSD -9.1k
MSI GTX 1660 Ti Gaming 6GB -21.8k
Antec NX210NX Cabinet -3.5k
Antec NeoEco 650M 650W -4.7k
BenQ GW2780 27inch LED IPS Monitor -14k
CoolerMaster MS110 Combo -4.8k (mdcomputers.in)
Total -98.9k
All above prices are taken from vedantcomputers except specified above.
Buying 1660ti new doesn't make sense , either buy used 1660ti or get 1660super , it's cheaper and has almost similar performance
