krishna_chennai
Hi All,
So I am here again looking for help from all experts for a decent WIFI router. Following would be my criteria which I guess is quite elaborate Please be informed that I am a noob in this and would not be able to elaborate things any better
To be used for Home networking t0 connect my PC/xTreamer/& Other Gadgets
Preferably 'N' standard router (Just to ensure that I have the latest, If you have a great G router which is better than N basic ones, Please suggest)
Looking to use the same as torrent downloader on a longer run (Read 1 month)
I have too many walls in my place hence signal strength has been to be decent.
I am not very particular about a brand just make sure that the model is available without much of trouble
Budget would be max 5k strechable to 6k best case...Lemme know if you have a should buy choice. I am ok if my budget goes little more for that
I guess thats a long list for you all to understand...Hoping for some great suggestions Thanks a lot for your visit and suggestions
