PC Peripherals Need Help: No Signal (Display) issue, Ryzen build
maddy_in65
Forerunner
I am facing this issue since last week. This build was powered on after approx. 1.5 years and was working fine before that.
Specs:
Ryzen 5 2400G
Gigabyte B450 Arous M
8GB Corsair RAM
250GB M2 NVME SSD, 4TB WD
Corsair CX650M
Benq GW2780
I have changed HDMI cables, tested with different monitors, DVI cable but no display. Removed CMOS, reseated all components again but nothing worked.
All Case, CPU fans works fine, there is no diagnostic LEDs on board so don't know which component is failing. One thing I noticed that KB didn't work as I see RGB lights come first time and then goes off. Does this mean there is issue with board. I am confused whether its Motherboard problem or any other component is failing.
Reactions: Stronk
Based off what you've said, it does seem that the mobo is the culprit - with the keyboard being the biggest giveaway as you've rightly observed. If possible, try using your chip in another system (a shop or a friend's compatible pc) to see if it worka there.
Reactions: maddy_in65
Specs:
Ryzen 5 2400G
8GB Corsair RAM
Corsair CX650M
Benq GW2780
I had a client who had a similar issue, in his case it was the NVMe SSD not being plugged in properly but it could be with anything from bad USB or storage device drivers or a corrupted bios.
try these trouble shooting steps:
1) Remove all the USB devices( keyboard, mouse, etc), HDD, SSD and try powering it on and see if you can get any display output.
2) Flash (if possible using bios flashback) or switch to the second/backup bios (your mobo has dual bios) preferably by shorting the pins on the mobo or using a jumper.(refer your motherboard's user manual)
If step 1 fixes the issue then plug one device at a time to check which device is causing the issue, boot into windows without the device, plug it back in once inside windows, uninstall device from device manager and restart.
If step 2 fixes the issue, there's nothing else to do, you're all good to go.
1.5 years? Check for weak cmos battery.
My Asus behaves abruptly when on drained battery or even weak ones so first do a bios reset followed by replacing with a new battery.
Also, pr my exp. if your system is idle for months or yrs the cmos battery tends to drain faster but when system is in use daily/regularly, the battery lasts 3yrs. Just my exp. with all the systems I had till date.
@THE PC BUILD: I have removed all components except NVME SSD but will check by removing everything. There is no display coming up so not sure how I can flash BIOS. BTW I dont have any prior experince of flashing BIOS.
@nRiTeCh: I will replace CMOS battery and test.
Thank you all.
Some motherboards have a "bios flashback" function, in which you have to only connect the 24 pin power to mobo (no other components/power cables needed) and a USB drive (usually formatted to fat32) in a specific USB port and usually press a button to begin the process of bios flashing, which can take about 5-10 mins. Just search online if your motherboard supports this, and if so, there will probably be a YouTube guide for the same as well. Good luck!
Also, if you have removed CPU recently check the CPU pin once for any damage or paste; clean it & try once. Also check the SMPS separately.
Reactions: Stronk
They have made it pretty simple.. just download the bios/rom from another pc, copy it in a pendrive, plug it in one of the usb slots on your mobo, power on, bios should auto detect crash and should start flashing processes on its own. But before jumping into all this refer to your mobo manual as sometimes for flashing bios some key needs to be pressed.
