articles2004
Hi all,
Basically Iam looking for a pc which will let me play games like GTA IV & be ready for GTA V (too much of an ask with 40K, is it?).
I do play games likes sniper elite v2, mafia 2 & assassins creed 2. I already have a studio laptop in which Ive tried playing all of these but only ended up getting fantastic fps ranging 10 to 20
Btw, I hope to use the pc as a stand alone computer which helps me in daily coding practice & gaming on weekends (so atleast 1TB internal hard disk)
Q: What is your budget?
40K
None
None
Leave it all to your expert advise. (Btw, I keep reading in forums that ASUS allows one button click overclocking)
No
Hyderabad/ Chennai
Open to online purchase
Yes
Practice office work on weekdays
Gaming on weekends
None
GTA 4, Mafia 2, assassins creed revelations
Gaming - 1280x728
Desktop - 1440x900
Yes
No preference
In toto, build is left to your expert opinion.
Just few suggestions from my side:
1) If possible I would like to delay buying the graphics card till Jan (gaming eating into my study);
2) I need atleast 1TB hard disk;
3) Need info on everything (case, wiring) that are needed to complete the PC (saw few just mentioning overall specs).
Tks all for the trouble,
SK
40K
None
None
No
Hyderabad/ Chennai
Yes
Gaming on weekends
None
Gaming - 1280x728
Desktop - 1440x900
Yes
No preference
SK
