Thank you so much bro. This is very relieving because I'm stressing out if the house would turn out good enough.Congrats on your new house bro.
Will show these sketches to my dad and my chief mason and let you know any suggestions. (They strongly believe in vastu and have good knowledge in it)
Yess. Thank you! It means a lot. I've been working on it for over a week now. I had a better plan but the enginner said it's not as per vastu so this is the final version.Have you designed/plotted everything on your own? Its great!
For vastu you haven't mentioned four cardinal directions so I assume the top is north facing by default how the map points.Yess. Thank you! It means a lot. I've been working on it for over a week now. I had a better plan but the enginner said it's not as per vastu so this is the final version.
Oh my bad! It's a road facing West plot. The top is East.For vastu you haven't mentioned four cardinal directions so I assume the top is north facing by default how the map points.
I've tried this idea but the problem is that there's a multistorey building to the East and if I place the living area there then there won't be much sunlight into it.Is it possible to shift the living area from SW to NW in the ground floor? The garage can then be at the SW? Or sitting area at the NE, garage NW & shift the room to SW?
Are you a vastu expert?Kitchen is on the ground floor at SE, right? perfect.
1st floor MB is on the SW right? perfect.
1st floor NE : space for Puja/guest room?
Good! Will connect with you if I require anything.I'm an avid student of the subject
Kitchen and MB is SE and SW you got that right. NE is a storage room or I might use it for workout.
Moving the room to SW is also a problem because dad doesn't want the room to be right next to the road since it's not safe.
Also, I like the idea of garage in the SW but where would the main entrance for living area be then?
You're absolutely right. That was our initial plan as well but the cost went up a lot more than we expected. But it has a major problem too. When parents get to old age they'll find it difficult to take the stairs everytime they have to go out and get back.I suggested them to lift the house 1 floor up and leave the ground floor empty as a parking. The increased cost is very marginal plus it doesn't count against the FSI. Today, single car parking may suffice but it might become insufficient for future needs. Keeping ground floor empty as parking will give ample space to expand in the future.
