Need little help with Metro-city people
Being.smart
Galvanizer
I am unable to find a 20ft or 20ft++ HDMI Cable in radius of 100km from my city.
Ordered one from Ebay.in which was shipped from USA 2 week ago, but still i hadn't received :(:(
I request if anyone of you have little time with you, please buy a HDMI cable for me
and ship it to me, i will reimburse you the cost :(
I need the cable little bit urgently, since my false ceiling is about to get over, and i want to put the cable under it :(
Did you try contacting with the ebay seller on why the item is still not delivered ?
If it was some HK seller on ebay.com then it was understood but with ebay.in the time is too much.
^ it was to be shipped from Chicago seller, i forgot to look item location before ordering it :(
Till date he had been saying, stuck in mumbai custom,
After loads of mail today, got this reply today morning
Code:
Dear Vipin Bhuarya,
Your Item is on its way to your address. Here is your tracking number. You would have either received it by now or will receive it shortly.
Courier: Hand Delivery
Tracking Number: 37801-44173
Item: Aurum Ultra Series - High Speed HDMI Cable (30 Ft) With Ethernet - CL3 Cer-QTH
Sorry, I use a 30Ft HDMI single piece cable, works perfectly for 1080P (1920x1080) - Now over 4.5 years. BUT previously tried the joints method using 3ft & 5ft pieces, never worked out.
@op check with customs?
Reactions: Being.smart
I don't know but isn't that applicable only to analog signals ?
Well i have seen DVI cable exhibit loss in signal strength over higher cable lengths which is digital signal, i dont know how HDMI would fare as HDMI is not just video signals but audio as well,
i had seen an issue 2 years ago while i was helping a friend setup a discotheque where he was using laser projectors ,normal projectors and Large screen plasmas which were setup to be controlled by a workstation and we had some visible distortion even when we were playing blue-ray content , and ruled out the issue to be with signal loss and had to use an amplifier /booster to achieve the optimum signal gain
The seller has provided me a local tracking number, but didnt specified which courier it is :(:(
so should i wait another 1-2 days, or try to get it from someone :(
Can anyone identify which courier tracking it might be ??
