Budget 0-20k need sleeper cabinet suggestions
want to shift to sleeper cabinet that supports a 120mm single or dual rad. No glass,no transparent crap no just old school cabinets. Would prefer something from corsair/cooler master/fractal etc basically office,business look. some vents for fans okay just no tempered glass
get CoolerMaster Elites one from OLX or FB Marketplace - you will find them around 1k and good thing is - they come up with more HDD bays than any of the above mentioned ones. You can add rad support by using dremel and cutting it through. Even with all this - your overall cost will not exceed 2k or 2.5 max and since you'll be using it as sleeper PC looks will not matter much.
this can be doable,thanks for the tip. older cases were the best had so many expansion options.
