DigitalDude
At present I'm having APC BI100I Pure Sinewave Inverter with Exide Invasafe 150AH x 2 SMF batteries. the batteries recently died a painful death (slowly giving less backup over 2 months). local inverter electrician says the SMF batteries are not suitable for inverters especially for heavy usage like high end PCs and will have low life. mine lasted 19 months . Now the BI1000I I have has a switchover time of ~20ms which was enough for not restarting my PC with Seasonic S12II 520W PSU during power cuts. they both carry on well during low loads. it's only when I'm gaming, sometimes, the PC restarts. As I'm planning to get new tubular batteries, I've decided to get a new Inverter also.
After searching for various Pure Sinewave inverters I've narrowed down my choices to 'Luminous iON 1500VA Digital Pure Sinewave Inverter' and 'Su-kam Shiny 1500VA Pure Sinewave Inverter'. while the fact sheet of luminous model clearly says the switchover time (mentioned as transient time?) as ~10ms, there is no data for the Su-kam model. Also reading online recommendations, people are suggesting Exide Inva Tubular batteries as popular choice but my local inverter electrician says it is better to go for same inverter brand tubular batteries incase of Luminous (InverLast tall tubular batteries ILTT 18048 150AH) or Su-kam (Su-kam tall tubular batteries 150AH) for better compatibility and support (makes sense but still...)
So I need your opinions and comments on the foll:
* switchover time? do any of you have above inverters? does your PC restart at high loads? in normal mode and also in UPS mode?
* above luminous model or the su-kam one? or something else? (how are Numeric ones?)
* same inverter brand tubular batteries or Exide Inva Tubular IT500 150AH batteries?
* does battery equalizers increase battery life ?
_
_
