Budget 31-40k Need suggestion for Dual Monitor Setup
ItsMeJebus
Hi, I am looking to have dual monitor setup to have better productivity as right now I am using ubuntu on sony vaio laptop which I am finding inadequate.
Can someone suggest me what kind of monitors/hardware should I get ? any where to check the hardware first (I am in Bangalore though ezone don't have such configurations) before buying it ? I am unsure about budget so selecting 30k to 40k, I just need it for browsing and development
You should go by this config
AMD FX 6300 Processor- RS.7700
http://www.snapdeal.com/product/amd-fx-6300-processor/1463312?pos=0;1
Kingston HyperX DDR3 8 GB - Rs.4536
http://www.flipkart.com/kingston-hy...perx&ref=3dad8139-1544-4d31-88b3-f0297c4751f8
MSI 970A-G43 - Rs 5196
http://www.snapdeal.com/product/msi-970ag43-motherboard/1177339
500GB Wd Blue- Rs.3370
http://www.snapdeal.com/product/wd-caviar-blue-wd5000aakx-internal/186189?pos=0;1
Seasonic 520W Power Supply - Rs.4543
http://www.snapdeal.com/product/seasonic-520w-power-supply/1379226?pos=6;17
Cooler Master Chassis K350 Cabinet - Rs3745
http://www.snapdeal.com/product/cooler-master-k350-cabinet-rck350kwn1en/1386390
Dell S2240L 21.5 inch LED Backlit LCD Monitor - Rs9440 x 2 = 18880
http://www.flipkart.com/dell-s2240l...240l&ref=d5ad4086-0775-4a0c-92f1-f024d9e42d42
ZOTAC NVIDIA GeForce GTX 650 Ti Boost 2 GB GDDR5 Graphics Card - 12440
http://www.flipkart.com/zotac-nvidi...oost&ref=58645f60-318f-4673-954c-0fe9277e2c13
Total = 60410
you can get some of the products cheaper locally.
Well, with such a low budget, you will need to go for the following:
2 x 20 inch Dell monitors (2020M or something similar). They should cost about 5 to 6K each and have a 720p resolution. They will need to have a VGA input as well as a HDMI/DVI input.
Intel Core i3 2nd gen or 3rd gen
H61 or B75 motherboard. It should have a VGA as well as DVI/HDMI out.
4GB single RAM stick clocked at 1600MHz. Corsair or G Skill.
The other components you can add as per your requirement.
Use a DVI cable for the first monitor and VGA for the second monitor. If you have spare cash, opt for a GPU if needed, but mostly, the IGP should be enough as long as you stick to browsing and dev work.
This is just a generic suggestion.
