Hi
I have this weird problem, so some inputs are appreciated.
I have an APC BR1000IN UPS and since the past 2 days, as soon as I switched my pc on it was going in overload protection mode, i.e long beep and was cutting the output power.
since yesterday, as soon as I try and switch the pc on, the ups is going in overload protection and MCP of my room tripping.
At first i thought it was a psu issue or something and removed all the cables of the psu that are connected to the motherboard and the rest of the components, even so, the UPS was giving the overload beep, so i connected another psu, just the psu and nothing else and didnt even hardwire the psu to boot as u do by crossing the green cable with ground, still the UPS would give overload beep, thought it was a UPS problem and connected the psu directly and bam, blown psu and tripped MCP.
now I only have 1 psu to test and ive tried 3 different power cables to connect to the ups but still the outcome is same, the ups is turning on fine otherwise.
I have tried the same by removing the input of the UPS from the wall socket to just run it off battery but to no avail
am absolutely clueless as to wth is happening, any inputs are greatly appreciated, thanks.
