Markus Leonhardt has taken the shortest route possible to liquid cooling.
1. throw motherboard in fish tank
2. cover in vegetable oil
3. there is no step 3
all he'd probly have to do is replace the stock fans with something of a higher power rating to counter the increased density. Apart from that, its all the same...oil is a fluid after all.Nikhil said:Call me an ass.... but I don't believe it. If it is oil, then the CPU fan and the GPU fanm will not work properly.
And you cannot immerse the whole thing in oil like that. He has immersed the PSU for GOD'S SAKE!!!
Exactly my thoughts.!!!:cool2:bottle said:fans could be useful to circulate the oil and help cooling. why hasnt any one asked if we can pair this with a prescott make frech fries ?
You don't keep the fan on the CPU, you'd be better off with a pump of some sort going over the heatsink to ensure the convection is more even and you don't get patches of hot oil.
Well, the hot oil from the chip and mobo rises to the surface and cools down when exposed to air, which again goes down to cool the proccy and mobo. Temp differences will be minute, but the shear bulk of oil compensates for that.anishcool said:Exactly, that is what I am saying. When your CPU, Mobo, GPU heats up, the oil will heat up too right ? After a few days you can bet it will be atleast a few degrees hotter depending on the type of oil. Then what do you do ?
Theres a little black box with a silver front panel, and a green tube running to the top on the extreme right of the tank. Whats that
