Online Broadband Speed Monitor
i m sure there are many online sites which check your broadband connection speed and other details for free... can any one name one of them.........
also add such links to the te recommendation thread na.. nothing much in that thread...
Airtel's B/w has given me good results, coz all the others hv tried showed a low speed, i mean they showed around 112kbps , 256kbps connection, airtel showed around 212kbps and +......
People asume that Airtel's speed test shows speeds higher than it really is. I dont think so. Some tests show me quite low speeds. I have gopt fed up with this.
The tru way of knowing your speed is to download 3 files from a HTTP source and add the download rate of all three.... This is the most accurate way of knowing your speed.
if you are on airtel, then it will show the closest to the max speed possible. on my 256k connection, i get around 245k when running the airtel speed test
Hi bluediamond,
You may check www.netlimiter.com.it has got various chart
and connection speed metres.however the download &upload speed shown
seems to be unreal you can rely on it for the downloaded,transmitted data to
your pc.though its a 28 days trailware there is a free version too.
softerman
