Budget 31-40k PC For CAD and Light 3D Modeling
Viz
Questions
  1. What is your budget?
    • 40K
    • None
    • None
    • Please Suggest
    • would like to upgrade in the next 2-3 years, probably RAM
    • Online
    • No
    • Office work AutoCAD and Revit (not heavy modeling though), so must be reliable with little downtime.
    • No
    • No
    1. 21.5" Screen
    • No
    • Windows 7 64 bit
I am not sure if the budget is sufficient to build a decent PC that can be useful for the next 3-5 years, please let me know your valuable suggestion, thank you in advance for your time
Intel Core i5 4440 -11000,
Gigabyte B85M-D3H -5500,
Kington HyperX Fury 8GB(2*4GB) -5400,
WD Caviar Blue 1TB-3500,
Deepcool Tesseract SW -3300,
Dell S2240L 21inch LED IPS -7500,
Corsair CX500 -3500,
Logitech MK200-800.
Total -40,500.
Hi Sunil,
Thanks for the response, I was thinking of raising the budget and getting a graphic card, http://www.snapdeal.com/product/nvidia-leadtek-quadro-k-420/664910881146#bcrumbLabelId:305, Please sugest
Also the Cabinet you had suggested is not available on Flipkart, Amazon or Snapdeal, can you suggest an alternate.
Instead of two Kingston HyperX Fury, how about this one - http://www.snapdeal.com/product/corsair-8-gb-ddr3-ram/1430570
Don't really understand the difference but this one is coming slightly cheaper than the PSU you had suggested - http://www.snapdeal.com/product/corsair-vs-550-smps/509795 abour 500 lesser, is that ok?
Thanks again for all your help.
Hi Sunil,
Leadtek Quadro is ok. Deepcool Tesseract is available at amazon.in and go with Kingston Rams as they are gud and running 2 sticks in dual channel mode will help in your pc performance.
