santoshdhn
- What is your budget?
- 20-22K
- Monitor - AOC 23'' IPS I2353
- HDDs - 02 Seagate HDDs (500gb & 160gb)
- Speakers - Z5500
- Sound Card - Asus Xonar D2X
- UPS - APC 600 VA
- CPU-1.8 core 2 duo E4300,
- M/B- Intel DG965WH,
- RAM - 2 GB Corsair value select,
- PSU- cheap local PSU 450 watts ,
- Cabinet- cheap local cabinet,
- Monitor-Samsung 943bw,
- UPS - Microtek 800VA double battery
- All of the above from 1-5
- INTEL
- CPU - Intel 4th gen 4430 or 4th gen pentium dual core or 4th gen i3
- Motherboard - Any good reliable M/B with USB 3.0 back & front support, Sata 3 - 6 GB/s, VGA & HDMI output, SPDIF output.
- RAM - Corsair Vengeance 4gb (1600mhz) or G Skill ripjaws x series 4 gb
- PSU- Antec VP450 or any local psu ( antel bp300 is out of question due to 03 sata power connectors)
- Cabinet - Any good cabinet with USB 3.0 front support or any local cabinet
- AMD
- CPU - AMD A10 6600 or A10 6800k ( is there any difference in graphics between the two)
- INTEL
- Will add a blue ray writer in the near future once becomes cheaper like the dvd's are
- Nehru Place, New Delhi
- NO
- basic Gaming like need for speed
- Heavy Browsing opening 15-20 browsers at a time
- Watching TV
- HTPC
- Download rig, 24x7 operation
- Watching HD movies
- Burning media
- Photoshop and Winzip
- No
- basic gaming, not a hardcore gamer and never used a graphics card nor intended to use it in near future
- 1920 x 1080
- No
- Windows 7 or Windows 8
