Budget 41-50k Please help buying laptop for home use
ashutosh25
New Member
Recruit
hello friends
i want to buy a good laptop (preferably ASUS,but other brands suggestion also works for me) for my school going kid for learning,light coding and light gaming purpose next 4 to 5 years use and budget would be around 40 to 55k, configuration required are as under
minimum intel i5 or any equivalent brand processor,
SSD or hybrid drive
min 8 Gb RAM (up gradable)
14 to 15 FHD display,
best screen-to-body ratio
good webcam,
back lit keyboard,
anti glare display,
dedicated graphics card
pls give your
valuable suggestions
Amien
How important is portability to you? A dedicated graphics card will cost you a good chunk of the budget while pushing it upto around 60k. Its also not needed for 'light gaming' as AMD integrated graphics will suffice. You will also need to give up most thin/lightness so make sure it's something you really need if going that route. Same goes for upgradable RAM, backlit keyboard and other nice-to-haves but not essentials.
ashutosh25
New Member
Recruit
thank you for reply friend, lightness and thinness does not matter much but screen to body ration required, and im ready to give up for up gradable RAM and integrated graphic card,
so then pls suggest me which laptop is best suited
jeffroberts
Banned
Recruit
Here are some laptops you can check if you haven't make any decision.
https://www.amazon.com/ASUS-IPS-Type-GeForce-Gigabit-FA506IH-AS53/dp/B0865THZCL/
ASUS A15 Gaming Laptop
Screen size15.6"
Display TypeFHD IPS-Type (1920x1080)
Graphics CardNVIDIA GeForce GTX 1650 4GB GDDR6
ProcessorAMD Ryzen 5 4600H (up to 4.0 GHz)
Ram8GB DDR4
HD512GB PCIe NVMe M.2 SSD
https://www.amazon.com/HP-Pavilion-Micro-EDGE-Processor-15-dk0010nr/dp/B07RX2XXPR/
HP Pavilion Gaming Laptop
Screen size15.6" diagonal
Display TypeFHD IPS Anti-Glare micro-edge WLED-backlit Display with 60Hz refresh rate
Graphics CardNVIDIA GeForce GTX 1050 (3 GB)
ProcessorIntel Core i5-9300H
Ram8 GB SDRAM
HD256 GB SSD
If you are ok with big screen size laptop you can also check this laptop, Im also using the same model
https://www.amazon.com/HP-Computer-Quad-Core-802-11ac-Bluetooth/dp/B082NZX92C/
HP Premium Laptop
Screen size17.3" diagonal
Display TypeHD+ SVA BrightView WLED-backlit 60% NTSC, 220 nits brightness (1600 x 900)
Graphics CardAMD Radeon Vega 8
ProcessorAMD Ryzen 5 3500U Quad-Core Processor @ 2.1GHz (4 Cores, up to 3.7GHz, 4MB Cache)
Ram12GB DDR4-2400MHz SDRAM
HD256 GB SSD
https://www.amazon.com/ASUS-VivoBook-i3-1005G1-Fingerprint-F512JA-AS34/dp/B0869L1326
ASUS VivoBook Thin & Light Laptop
Screen size15.6 inch
Display TypeFull HD (1920x1080) 4-way NanoEdge bezel display with a stunning 88% screen-to-body ratio
Graphics CardIntel UHD Graphics
Processor10th Gen Intel Core i3-1005G1 CPU (4M Cache, up to 3.4 GHz)
Ram8GB DDR4 RAM
HD128GB PCIe NVMe M.2 SSD
Otherbacklit keyboard with fingerprint sensor
https://www.amazon.com/FX505DT-R5-3550H-Processor-GeForce-Graphics/dp/B07ZTRMB9V/
Asus TUF Gaming Laptop
Display TypeFull HD (1920x1080) IPS-Type Display Thin Bezel , 120Hz
Graphics CardNvidia GeForce GTX 1650 4GB graphics (base: 1395MHz, Boost: 1560MHz, TDP: 50W)
ProcessorQuad-core AMD Ryzen 5 R5-3550H
Ram8GB DDR4
HD256GB NVMe SSD
If you have purchased your laptop, please do share the brand name and model.
Thank you
avesh
Member
check MI laptops, small, light weight, decent configuration and very good value for money,
