Poor man's Dremel ? 3M Scotch Brite Micro-fibre ?
PoBoy
Herald
Feedback: +15 / =0 / -0
DealExtreme: $22.67 Mini Electronic Drill with Cutting/Sharpening/Polishing Tools Kit
- Idea for modelers, jewelers, electricians, electronics and DIY'ers
- Apply to mould processing, repairing and burnishing
- Used to punch and drill holes on aluminum boards, thin copper boards, wood boards, plastic boards, chipboards, printed circuit boards, epoxy boards
- For gold and silver jewelry polishing
- To cut, polish and grind some precision components
- Ultra low and secure voltage power
- High quality magnet DC motor drive, ABS shell
- Package includes:
- 1 * Mini drill
- 5 * HSS (high speed steel) drill (diameter: 0.5, 1.0, 1.5, 2.5, 3.0mm)
- 5 * Collet (inside diameter: 0.5, 1.0, 1.5, 2.5, 3.0mm)
- 4 * Sanding drum
- 1 * Cutting disc
- 1 * Power adapter: AC 220V US type charger (110cm-cable)
DealExtreme: $2.56 3M Scotch Brite Hi-Tech Cleaning Cloth for Gadgets
- Great performance in wiping off oil stain and absorbing tiny dusts
- Washable and long-lasting
- Can be used to clean LCD's, computer screens, camera lens, the surface of precise instruments, cars and disks
the mrp of 3m Scotch Brite cloth is around Rs. 78/-. And it is available in major supermarket like Big bazaar, Hypercity, Shoprite etc. However the dealextreme cloth may be of larger size, but the size is not mentioned on DE site.
