PC Peripherals Power supply cable - wrong plug
What should I do because the PC is Useless
  • Look for an adapter
    Votes: 1 100.0%
  • Tell someone to build the PC for me
    Votes: 0 0.0%
  • Total voters
    1
Scuhtiya
Inactive
Apprentice
So I was finishing building a PC yesterday and found out that the power supply has an adapter like this(North American or EU version and on the box it says UK version) but taking a look inside the red cover I found this. The model is cooler master 450 MWE and here are some pictures
This is a UK plug.
The other end of the cable that plugs into your PSU is detachable, so you can get a cable with an Indian plug.
Edit: As Julian said above.
@Scuhtiya If you're wondering what the red thing is, It's a fuse holder and the tube is a 13 amp glass fuse.
Correct me if i'm wrong. Even this plug should work in any universal socket power strip we get now days. I think UK and India both have hot wire on right side. Plus indian plugs don't have fuses in them so no safety there. This plug is definitely superior than standard plug.
Reactions: tommy_vercetti
