FS: Others **Price Drop**Akitio EGPU+Dell 220watt power supply+cables
rohinsuri
New Member
Feedback: 2 / 0 / 0
Gurgaon
5 out of 5
  1. Cash
  2. Bank Transfer
Included in cost
No
No
Not required.
All components are hardly used and are in brand new condition.(Except dell power supply)
EGPU- Rs.14000
Dell(da-2) Power Supply- Rs. 3000 (The EGPU comes with its own power supply that us unused but is of very less wattage and hence cannot be used to power a GPU)
Cable - Rs.1000 - I specially designed this cable which can power the EGPU and a graphic card from the same dell power supply
(Can provide more spare cables-price extra.)
There is a slight cut on the out shielding of the dell power supply but it works fine. (Photo attached.)
Please note that the 8 pin power connector on the dell power supply is not a same as the PCIE 8 pin power connector found in the desktop power supplies hence the special cable was designed.
t3chg33k
Feedback: 8 / 0 / 0
May be you should term this as PCIe Expansion box and not as an eGPU enclosure since it is not meant to be one despite the power supply change. The Thunderbolt 2 / PCI Express 2.0 interface isn't ideal for an eGPU.
rohinsuri
New Member
Feedback: 2 / 0 / 0
Well I have used a GTX 1060 6gb version and the performance was within the delta for 15% when compared to running the GTX 1060 in a desktop. So it's very successful in running GPUs. You can always use a desktop power supply to give power to the GPU. The power supply I am giving makes the setup cleaner. Also there are a no. of validated EGPU builds with this enclosure on the 'egpu.io' forum website. So ya with this enclosure you really can super charge your laptop.:)
rohinsuri
New Member
Feedback: 2 / 0 / 0
Bump. Huge price drop. New prices are as follows :-
EGPU box 11000 | Dell PS at 2000 | Cable 1000
Complete setup for 12000. (Further Discount)
