Problem with CM Hyper 212 EVO
random2
Inactive
Galvanizer
I got this just today through FK and I have an issue.
2 of the standoffs just dont fit with the provided nuts. The nut wont turn more than couple of turns. The other 2 are fine. I checked all the nuts with the 2011 standoffs and they seem to be fine. Should I ask for replacement or should I try to force it?
The last thing I want is jammed up standoff on the mobo without any solution. Anyone else had this issue?[DOUBLEPOST=1378041221][/DOUBLEPOST]Nevermind, solved it.
Fixed the standoff on vise and used the screw driver tip provided to tighten the nut. Ran through the same process 3-4times and it was fine. Had to waste some time for this.
