astrixgaul
Beginner
Hi,
I have a WGR614 v6 WiFi Router which was running fine for last two years or so.
Since last month, it started disabling my WiFi when the Desktop PC(on WIN 7) which is connected through a wired connection to the router was switched off.
As a routine debug measure I upgraded the firmware to the latest (Ver 2.0.19_1.0.19). Did the setup again for my WiFi N/W.
But now all my devices show that my network is available but won't connect and exit saying the "WiFi Network Remembered".
For the first problem "Wifi going off when wired PC is off" I got to know that WIN 7 "Homegroup" might be interfering with the Router setting. Is it correct ?
For the second problem "WiFi Network Remembered", can anyone suggest a solution.
Thanks
Thanks
