Rapidshare.com premium users OR mozilla users - Help!
jumbo5
I just reg as a RS.com premium user.
I've DAP 5.0 in which i integrated it with IE7 and also fed the username password.But when i paste the link in DAP or IE7 address bar (which eventually it leads to DAP) the file size to d/l shows 17 kb instead of 95 mb which is the file size.
In the Mozilla FF add-on 'Downloadthemall'..how 2 use batch decriptors?
It is also behaving like DAP.
Its only detecting the RS linx and not the file.
I.e it downloads the linx (15kb) not the file (95mb)
THere is no option in to enter RS username & pw here.
Pls give more suggestions & applications.
Umm... me a Premium user too. I just copy paste the links in notepad. And add them to Flashget. There is a option to give a username and password in the add a new download window there I enter my premium username and password. Viola!! I have downloaded more than 30 gigs this way.
yes, i agree with timback. after trying all the download managers. finally , idm is the best of them. gives me 230 kbps speed . i usually copy paste links in notepad and then import that text file. works very well
err.. ok..
First log into RS from IE. Fill in your UN and Pass and let it be. DONT delete the cookie from IE.
Now in DAP, u must be having a section where in you can permanently store UN and Pass for various sites such as rapidshare. (In flashget it is called 'Site Manager'). So here (in Dap), you put in RapidShare: Easy Filehosting. and Your UN and Pass in the UN and Pass fields. and voila your set to download!
This way you can copy paste the links from FF or IE you will (and should be)able to download complete files!
There is an option in premium to allow download as direct links..tick that option..
Then put the rs premium user and pass in download then download all you want..
