User Review RAVPower 16750mAh Power Bank Review
My opinion on RAVPower 16750mAh power bank.
Build and Hardware:
  • Hardware - Solidly built. The edges are smooth. Anti scratch does work well
  • Weight - It weighs 309g which is comfortable to carry around.
  • Convenience - It comes with travel pouch which helps to carry in bags. It also avoids any scratches.
  • Accessories - It also comes with two USB to mini USB cable to be used in those ports available.
Features
  • It supports dual USB ports - one 2.4A and the other 2.1A, together delivering 4.5A charge
  • These usb ports can be used to charge mobiles, tablets, and other gadgets
  • iSmart technology - it charges faster and smarter than others. Detects optimal charging setting automatically
  • Safety protection - short circuit and over current protection. Shuts down device if either happens
  • Flashlight support which is supposed to come handy at times. But personally I didn't find it much useful.
  • Note that it doesnt require explicit power on and off.
Performance
  • Charges the mobile phone quite faster.
  • It comes with 1.5A input for charging which is supposed to charger 2 times faster than other power banks.
Cons
  • If you charge it using some cables, it takes long time to fully charge.
  • After using for about 1.5 years, the ON button has become loose. But doesn't affect functionality.
Verdict
  • There are many variants like 3350, 16750 all the way upto 22000mAh.
  • The fast charging capability and good capacity makes it a perfect companion for any outdoor trips.
