Budget 41-50k Recommended Cooling for Ryzen 9 Build ?
pradeepg
Novice
  1. What is your budget?
    • 40K
    • CPU – Ryyen 9 3900x
    • Motherboard – Asus X570 ATX Crosshair VIII hero
    • GPU – Nvidia GTX 1050Ti
    • RAM – Corsair vengeance 2 X 16GB
    • Monitor – BenQ XL2411p
    • PSU – Antec VP500PC
    • Cabinet – Also Antec
    • CPU, GPU,Motherboard , RAM , Monitor , maybe PSU if it supplies the required demand.
    • Liquid Cooling
    • Cabinet that supports liqcooling.
    • Maybe a PSU if required.
    • Yes, will upgrade the GPU in future. maybe a GTX 3080 , if prices are good i might buy now.
    • Mumbai
    • Open to online purchase
    • NO.
    • Gaming
    • Browsing
    • Desktop Processing
    • HTPC
    • Download rig, 24x7 operation
    • Watching HD movies
    • Some Davinci Resolve and some blender.
    • NO
    • I only Play CSGO
    1. Gaming - 1280x720
    2. Desktop - 1920x1080
  1. Are you looking to overclock?
    • Maybe
  1. Which operating system do you intend to use with this configuration?
    • Windows 10 Pro
A Noctua NH-D15 will be able to sufficiently cool your processor without the hassle of liquid cooling and it performs better or at par with most AIO. Please check if the cabinet supports the height of cabinet
here you go!
