Folks, I have a requirement to run an extension cable from a plug and an ethernet cable from the router together using the normal external cable casing for 15m from one room to another.
The Ethernet cable I intend to use appears to be "unshielded" from the product description -
The electrical cable is of decent quality brought from the nearby store. It originates from a 3 pin plug.
Will it be an issue ? I also have the option of replacing it with shielded ethernet cable but will that mitigate the risks.
Edit : It's a rented flat so cannot do any much apart from this when it comes to cabling.
