SanDisk announces 512 GB Extreme Pro SD Card
mrmash
We always need a Extreme high-capacity SD cards for the New Cameras that can record 4K videos, which requires a very high memory card to hold all these videos together. SanDisk has now announced a new card that should make the life of any videographers a bit easier.
Today, SanDisk has announced the world's first 512GB SD card, that's half-a-Terabyte in a postcard size chip. Insert two of these in a camera that support two cards and you have a full 1 Terabyte of storage space available at your disposal.
The 512GB Extreme PRO UHS-I SDXC card is rated at a write speed of 90MB/s and a read speed of 95MB/s, which should be enough for high bitrate 4K recording or high framerate burst shooting. The card is temperature proof, shock proof, waterproof and X-Ray proof and comes with SanDisk's usual lifetime warranty and RescuePRO Deluxe data recovery software.
Unfortunately, It's Price is Extreme too, the 512GB Extreme PRO will cost around $799.99. But if you are someone who invests in expensive camera gear and can afford to spend on fast, spacious storage options, then this is worth considering.
