Scythe KAZE-JYUNI "SLIP STREAM" 120mm Case Fan-SY1225SL12SH-1900rpm
sumchamp
Explorer
Feedback: +43 / =0 / -0
I want these fans couldn't been able to find in India. Earlier it was available thru lynx-india but now they don't have stock of these.
Scythe KAZE-JYUNI "SLIP STREAM" 120mm Case Fan - SY1225SL12SH - 1900rpm
Newegg.com - Scythe SY1225SL12SH 120mm "Slipstream" Case Fan - Case Fans
Dimensions:
120 x 120 x 25 mm
Weight:
115g
Connector:
3-pin (3-pin to 4pin adapter included)
Bearing Type:
Sleeve Bearing
MTBF:
30,000 hours
Maybe I had a bad batch, but I bought three of these earlier from KMD and all three went bad within 6 months (they don't rotate anymore). Installation was in both orientations and I know some say the sleeve bearing ones shouldn't be mounted horizontally, but then even the vertically mounted ones went bad :(.
They were silent while they lasted though.
Thanks and I checked with newegg reviews, seems many of them faced similar issues. Hence , closing this thread. :)
