Infected
- Scythe Kaze Master Pro 5.25
- KM-03
- Rs 2500/- Shipped.
- 6 Fans Controller and 6 Temperature Display.
- Passive Safety Alarm Feature is Build-In!
- Clear and Stylish VFD Display!
Fan Controller and Temperature Monitor Features
- Kaze Master is able to control and monitor up to 6 fans and 6 temperature monitor independently. These figures are displayed on VFD display.
Alarm Sound with Mute Function
- To safely monitor and run your system, Kaze Master comes with the alarm feature to inform the user in case of fan malfunction. Also if the temperature goes above 75C (165F), or in case of the temperature sensor failure, VFD display will blink the number “0” or “0.0” and trigger the alarm sound. You can even shut down the alarm sound by a simple jumper setting!
2-Way Temperature Display
- Both Celsius and Fahrenheit unit can be displayed by a simple jumper setting!
Fan Stop Function
- By turning the knob to counter-clockwise all the way, the fan can be stopped.
Wide Variable Voltage to Control Fans
- You can control fans between 3.7V – 12V to meet your needs for system requirement.
- By setting the voltage to the lowest level can silence your PC or turn it up to the highest to get the maximum cooling performance.
