hello guys, have been using this one and after 1 yr of usage started experiencing power issues. I thought that this is only a cabinet front panel issue/cable issue and replaced cable for 2 times and cabinet for 1 time. This thing works out initially for a couple of monhts properly and then i face the same issue (the drive sometimes doesnt get detected and the amber LED blinks rapidly during that period). I have to disconnect/reconnect it sometimes even a couple of times to make it work . May be a loose conduct also..
Now when i connected this drive to my newly bought WD FULL HD media player for the 1st time it was OK. For the 2nd time when i connected, the same power issue and rapid light blinks. Very very frustrated.
Now I want to RMA it. Will they will send me a new drive/repaired one or return the same drive ? .
Has anyone used this drive (the exact model) ?. Please tell me what to do ?. I dont know about the assessment procedure of seagate....
