Phenomenal
Explorer
Hello,
I have a Seagate ST3500418AS 500GB (purchased in 2009,under warranty) drive from Mumbai (Lammy Road) and Hard Disk Sentinel shows that it has only 9% life left.
Also tested with HDDlife Pro Trial - 12%
Crystal Disk Info : Caution
It says there are 2000+ Bad Sectors on the disk surface and also it warns about the reallocated sector count.
Here is the exact message :
[TABLE="class: ncode_imageresizer_warning, width: 700"]
[TR]
[TD="class: td1, width: 20"]
[/TD]
[TD="class: td2"]This image has been resized. Click this bar to view the full image. The original image is sized 1021x515.[/TD]
[/TR]
[/TABLE]
Can I get this drive RMA'ed ?How do I go about it?
I plan to contact my reseller (Lammy Road Shop) as I have the proper VAT bill alongwith the serial number and original anti-static cover.
I heard Seagate gives a REFURBISHED drive and not a new one,is true?
What about the warranty on the new drive?
I am scared that only 14 days are left!
Backing up all the data now!
Also if it's not required then what is the significance of those errors and how can I fix them?
Please advice and also comment about your Seagate RMA experiences.
THANK YOU
[TR]
[/TR]
[/TABLE]
THANK YOU
