Hi Dear Techies,
I need advice on buying a split air conditioner 0.8-1 ton capacity with EER > 2, The lowest trustworthy brand that i can go for is videocon as i have a videocon LCD TV at my home it just does what is required. I can go for any new brand apart from the usual common ones (eg LLoyd etc).
My basic requirements:-
1) Beat the heat of this scorching mumbai summer which will start soon.
2) Will be using a/c for about 4-5 hrs max daily which includes 2-3 hrs at night time. And 5-6 hrs on weekends.
3) My electricity bill comes in the range of 1.1-1.4 K/ month, so this can be augmented by around 500 Rs for the AC consumption but not more than that.
4) Good After Service support.
5) No advanced features required. Just basic stuff like auto sleep mode, directional flow & bacteria filter (whatever it is called).
Let me know if anything more is needed for the suggestion. I am a intermediate level knowledgeable person in matters of AC. I was able to figure out my room would require a 0.8-1 ton AC, 5-star AC is not needed as my daily use on average would be very less and all other basic stuff.
So Feel free to pour in your suggestiions on this.
Regards,
Niranjan
Regards,
Niranjan
