Monitors strange problem with Samsung 19" LCD
stackoverflow
Inactive
Contributor
Hello,
I have a samsung 940BW.
The current driver I am using for the monitor is default monitor from windows.
I have also used the samsung driver which comes with the CD.
I am using Intel media accelerator 950, ie. on board graphics.
Problems
1. The default resolution is 800x600 and if I set to 1024x768 and reboot the resolution is back to 800x600
2. If I set the resolution higher than 1024x768 all the text appears blurred. It looks very bad, any clue?
3. Which monitor driver should I use?
4. Is the the problem with Intel Display driver?
Regards,
